DVD2oneX 2.0
28 réponses à ce sujet
Posté 08 novembre 2005 - 08:45
DVD2one vient de sortir en version 2.0, tant pour Mac que pour Windows.
user posted image
Tout a été refait :
QUOTE
After many, many months of hard work, we are proud to present DVD2one V2. This new version of DVD2one has the following features:
    * Completely new user interface.
          o Based on our own newly developed cross-platform GUI library.
          o Interface and usage of DVD2one2 is the same on both PC and Mac OS-X.
          o Release of future updates will be synchronous for both platforms.
    * Engine completely rewritten for multi-processor support.
          o Future ready for upcoming dual-processor cores.
          o Advanced grid processing possibility.
    * Compression engine further improved.
          o Choose 'best quality' mode for best possible image quality while retaining highest possible speed.
          o Choose 'fast' mode for fastest possible processing.
    * Builtin imaging and burning support.
          o No need for expensive 3rd party burning tools.
          o Choose between output as fileset, image file or burning to dvd-writer.
    * Bitrate and channel configuration of audiotracks is now read from the stream.
          o Size of audiotrack is now calculated.
          o Size and needed compression of video is now calculated.
    * Bonus: Audio Remaster functionality added to DVD2one2.
          o Improved remaster engine: upto 3 times as fast and improved sound quality.
          o SSE support on Intel and Alti-Vec support on PPC G4 and G5.
    * New licensing model.
          o License valid for one user OR one computer.
          o One user: If you are the only user, you are allowed to use the license on all computers you own (both PC and Mac).
          o One computer: If more people are using the license, then you are only allowed to use it on 1 computer.
En résumé et en français :
  • Nouvelle interface utilisateur (la même sur Mac et Windows)
  • Moteur réécrit pour tirer parti des multi-processeurs (multicore et grille de calcul)
  • Moteur de compression encore amélioré (qualité ou vitesse)
  • Gravure et création d'image disque intégrées
  • Le débit et la configuration audio est dorénavant lue dans le flux
  • En plus, Audio Remaster a été intégré à DVD2one
  • Nouvelle licence : c'est un utilisateur OU un ordinateur
Licence pleine à 40 euros et mise à jour à 25 euros.
#2 tutu13
tutu13
  • 129 messages
Posté 08 novembre 2005 - 10:36
Quelle rapidité !
Avez-vous comparé Automatic/Low/Med/high ?
S'agit-il de la vitesse à laquelle DVD2oneX encode?
Cela influe-t-il sur la qualité du rendu, même si l'on reste en "Best quality"?
#3 tutu13
tutu13
  • 129 messages
Posté 08 novembre 2005 - 11:21
je n'vois pas de différence de qualité entre "Automatic" et "Best".
Posté 08 novembre 2005 - 21:13
Je n'arrive même pas à le tester car il quitte dès le démarrage. D'après le forum de DVD2one, cette application ne fonctionne qu'avec Tiger actuellement. Une version existe pour 10.3, mais elle ne fonctionne pas avec 10.3.9 (elle a été testée sous 10.3.0).
#5 deff
deff
Posté 11 novembre 2005 - 12:19
j'ai testé la version démo, et je ne vois aucune différence entre low, medium ou high. C'est très subjectif à mon avis, et comme je ne suis pas professionel...
Il existe un flou artistique en tout cas : est-ce la compression ou la qualité qui est en low, medium, high ? Dans le doute je laisse medium.
Par contre, bravo pour la vitesse : mon bipro 2,5 Ghz (sous Tiger) met moins de 9 min à "encoder" 6 gigas de video, contre le double de temps auparavant.
#6 tutu13
tutu13
  • 129 messages
Posté 11 novembre 2005 - 13:34
mon 10.3.9 veut bien ouvrir la version pour Panther.
QUOTE
et moi sur "Automatic"
Avez-vous remarqué? Là où la version 1.4.2 affichait AC3 6ch, la 2 affiche AC3 3/2.1
Avez-vous essayé le Burning?
Modifié par tutu13, 11 novembre 2005 - 13:57.
#7 adesir
Posté 11 novembre 2005 - 17:03
Je confirme : la nouvelle version pour Panther fonctionne sous 10.3.9 et pour cause.
QUOTE
Another try ...
It turned out that we still used 1 method that is not available in OS-X 10.3. We now changed this into another method, so the 10.3 specific build of DVD2oneX V2 should now also work on 10.3.9.
#8 deff
deff
Posté 14 novembre 2005 - 09:51
Je n'ai pas essayé le burning directement à partir de DVD2oneX, je continue d'utiliser mon bon vieux Toast (je le rentabilise, vu ce qu'il m'a couté !).
Petite precision au passage, je suis sous OS X 10.4.2.
#9 adesir
Posté 19 novembre 2005 - 16:15
DVD2oneX vient de passer en version 2.0.1.
QUOTE
Here's a new version of DVD2one with the following features:
    * Fixed problem with Audio Track selection in Full Disc Copy mode.
    * PC: Improved DVD writer detection. This should solve startup problems that some people were experiencing.
    * Mac: Added burning support for OS-X 10.3.
    * Added maximum write speed selection.
    * Some other small internal improvements.
En français :
  • Problème avec la sélection de piste audio en mode Full Disc Copy résolu.
  • Ajout du support de la gravure pour Panther
  • Ajout de la sélection de la vitesse de gravure maxi
  • Autres petites améliorations internes
Lien direct de téléchargement : http://www.dvd2one.c...dvd2onex201.zip
#10 adesir
Posté 07 décembre 2005 - 13:29
Nous recherchons quelques personnes utilisant DVD2OneX 2 pour participer aux tests de sa traduction en français.
Merci de me contacter par messagerie privée ou par mail (l'adresse est en bas de la page) si vous pouvez nous aider. Le seul objectif est de tester et - éventuellement - de peaufiner les termes francisés.
Merci,
#11 adesir
Posté 09 janvier 2006 - 20:51
Et voilà, DVD2OneX 2.0.2 vient de sortir.
user posted image
Les nouveautés :
  • langues ajoutées : français, allemand, italien, portugais et espagnol,
  • Jolis icones d'arborescence ajoutés
  • le menu système maquant sous OS X 10.4 est corrigé,
  • compilé avec GCC4. Les utilisateurs de Panther doivent être en version 10.3.9 pour cette version.
Merci à Japico et KCd pour la vérification de la traduction. Je suis évidemment preneur de toute proposition d'amélioration. wink.gif
Lien direct de téléchargement de cette nouvelle version : http://www.dvd2one.c...dvd2onex202.zip
#12 adesir
Posté 02 février 2006 - 18:48
DVD2One vient de passer en version 2.0.3.
Les nouveautés intéressantes :
  • Ajout du langage Coréen
  • Correction d'un petit problème avec l'audio par défaut activée et la piste sous-titre (les pistes marquées avec *)
  • Correction d'un problème de pistes audio manquantes en copie complète de disque
  • La gestion des conditions d'erreur provoquée par des données corrompus dans la source a été modifiée.
  • La sélection automatique du langage pour l'interface utilisateur a été ajoutée au lancement.
  • Amélioration de la vitesse du programme grâce à la réécriture des routines de lecture et écriture et à l'optimisation du traitement en qualité maxi.
  • Versions PowerPC et Intel natives : Universal binaries. Le code natif Intel va deux fois plus vite que le code PowerPC dans Rosetta.
Lien direct de téléchargement (fichier .zip de 784 Ko) : http://www.dvd2one.c...dvd2onex203.zip
#13 adesir
Posté 09 mars 2006 - 18:35
Et encore des corrections pour DVD2OneX qui passe en version 2.0.4.
Les nouveautés :
  • Ajout des langages suédois et hongrois.
  • Correction d'un petit problème : des entêtes corrompus dans le flux vidéo pouvaient planter DVD2One.
  • Modification de la méthode de gestion des erreurs de mastering en mode copie complète : au lieu de donner une message d'erreur et d'arrêter le traitement, les erreurs sont maintenant corrigées et un message est affiché à la fin du traitement.
  • Option ajoutée pour un dossier de destination fixe.
  • Désactivation d'une option de compilation qui empêchait DVD2OneX de fonctionner sur un G3.
Lien direct de téléchargement (fichier .zip de 800 Ko) : http://www.dvd2one.c...dvd2onex204.zip
#14 adesir
Posté 18 mai 2006 - 18:16
Une petite mise à jour pour DVD2one2, qui passe en version 2.0.5, avec les nouveautés suivantes :
  • Changement de la méthode qui détermine quels titres sont affichés en mode film seul ou jointure,
  • Correction d'un problème qui faisait planter DVD2one avec des fichiers IFO vides. Cela résout le problème avec MTR 3.0r13d,
  • Correction d'un message d'erreur quand aucune cellule n'était sélectionnée pour un titre.
Lien direct de téléchargement (fichier .zip de 800 Ko) : http://www.dvd2one.c...dvd2onex205.zip
#15 cedcedcac
cedcedcac
Posté 06 juin 2006 - 18:54
bonjour à tous,
je suis peut-être neuneu, mais je ne suis pas arrivé à joindre 2 faces d'un DVD sur une simple face avec ce logiciel.
en effet, il s'gait d'une serie avec 4 episodes/face à l'origine et lorsque je les regroupe, je ne retrouve pas tous les episodes, tous les fichiers semblent pourtant être sur le disque...
PS: ça marchait très bien avec une ancienne version de DVD2one...
si qqun a une idée ou un petit tuto pour regrouper 2 faces sur une seule avec DVD2ONE V2, ce serait vraimant sympa, je sais plus quoi essayer là... sad.gif
#16 adesir
Posté 28 septembre 2006 - 20:32
Une nouvelle petite mise à jour pour DVD2one2, qui passe en version 2.0.6, avec les nouveautés suivantes :
  • Ajout du chinois traditionnel.
  • Ajout d'une option demandée pour changer la priorité du programme. Il est maintenant possible de régler DVD2one comme un processus d'arrière-plan, pour pouvoir travailler avec d'autres applications (évidemment, la recompression prendra plus de temps).
  • Correction d'un petit problème sur Mac : un fichier de préférences abîmé pouvait faire planter DVD2oneX au démarrage.
Lien direct de téléchargement (fichier .zip de 816 Ko) : http://www.dvd2one.c...dvd2onex206.zip
#17 adesir
Posté 07 décembre 2006 - 07:59
Une mise à jour assez importante pour DVD2One, qui passe en version 2.1.0.
En effet, cette version apporte le traitement par lot, très demandé. Vous pouvez maintenant programmer jusqu'à 15 disques pour qu'il soient triatés les un derrière les autres, sans intervention. De plus, le système de fichiers du disque de destination est maintenant vérifié. En effet, les disques formatés en FAT32 (quelques rare disques externes sur Mac) ne peuvent accepter des fichiers de plus de 4 Go, ce qui les rend impropres à accepter les images disques typiques d'un DVD.
#18 adesir
Posté 14 décembre 2006 - 22:52
Une petite mise à jour pour DVD2oneX qui passe en version 2.1.1 : correction d'une problème de fonctionnement sous Mac OS X 10.3.9 et mise à jour de la traduction allemande.
#19 adesir
Posté 27 février 2007 - 20:34
Une mise à jour conséquente pour DVD2OneX 2.1, qui passe en version 2.1.2 :
  • le nom du DVD n'est plus converti au standard ISO,
  • séquence de gravure par lot améliorée (éjection),
  • correction de l'avertissement en mode par lot si un seul disque est éjecté,
  • correction des images 4:3/16:9 et PAL/NTSC par titre,
  • mise à jour des traductions italiennes et portugaises,
  • l'option "nom du DVD selon la source" lit maintenant le nom du volume s'il n'y a pas de dossier parent,
  • correction d'un problème qui n'affichait qu'un graveur de DVD si vous en aviez plusieurs du même modèle,
  • correction d'un éventuel crash sur annuler et quitter,
  • passage de la lecture des fichiers wave pour AudioRemaster de QuickTime à une procédure interne pour prendre en compte les fichiers à 96 KHz.
Cela fait un moment que la traduction de DVD2OneX 2 n'a pas été révisée. Est-ce qu'un utilisateur régulier pourrait faire une vérification de la traduction ?
Merci,
#20 adesir
Posté 11 juin 2007 - 17:05
Petite révision pour DVD2OneX qui passe en version 2.1.3. La traduction lettone trouve sa place, ainsi que la correction de l'écriture sur un volume réseau.
A télécharger ici : http://www.dvd2one.c...dvd2onex213.zip
