Transformer un DVR-109 en DVR-A09
19 réponses à ce sujet
#1 Guest
Guest
  • Guests
  • 1 549 messages
Posté 08 mars 2005 - 13:45
Sur le forum rpc1.org, certains sont parvenus en utilisant une petite application développé, par "initilal_D", à transformer leur graveur Pioneer DVR-109, en graveur DVR-A09.
Ce qui a pour avantage de ne plus avoir la vitesse d'extraction bridée à 2x, le firmware du DVR-A09, ne souffrant pas de ce bridage.
Il faut installer le graveur dans un PC, pour faire cette manipulation. Il n'existe pas de solution pour Mac actuellement.
C'est ici :
http://forum.rpc1.or...er=asc&&start=0
Voici en Anglais toujours les 2 posts les plus importants à mon avis concernant cette manipulation :
1°
QUOTE ("initial_D")
Hi! everybody
I have written a tool call DVRupdate (like DVRflash) can flash A09 firmware to ASUS1608p!
If you want to try,you can download form here
http://www.pcdvd.com...ad.php?t=449892
or write mail to me
This is my test. I hope you can understand the meaning!
(R91??009.1??)(R91??109.1??)
                  other OEM' type
    109    <==>  A09XL  <==> ASUS1608  <==> 109
(R9100009.005)(R9143009.105)(R9123009.102)(R9100009.105)
(R9100109.009)(R9143109.117)(R9123109.102)(R9100109.109)
PS: please using kernel file and normal from the same brand [/SIZE]
2°
QUOTE ("dvscuba")
Thanks to all who don't think I'm ridiculous.  Also to initial_D again for the tool and Flashman for the archives.  I hope I'm allowed to link to Flash's stuff here...
Here's what I did with as much of an explanation as I can provide:
http://p2pnet.net/story/4131
I extracted the A09v1.05 firmware
http://flashman.rpc1...VRA09_FW105.EXE
and deleted the Pioneer upgrade .exe.
I used the DVRupdate 0.9 from
http://flashman.rpc1.....date v0.9.zip
and flashed the A09 v1.05 firmware into the drive. This is where the DVRupdate tool came into play. I was already at v1.17 from Pioneer and they wouldn't let me flash backwards or to the A09 model (which is not rip locked). Then it was just a standard upgrade using the Pioneer .exe and v1.17 firmware for the A09
http://flashman.rpc1...A09_FW117EU.EXE
During earlier attempts and while examining the firmware files for differences, I had noticed the 109 has the heading "GENERAL" in the hex file while the A09 has the heading "PIO_ADV". Trying to flash the wrong version of the firmware from Pioneer wouldn't work. But the DVRupdate file allowed me to change the kernal portion also. The only place I could find the small kernal file was in v1.05. So now, the drive is still recognised as a DVR-109 v1.17 but the rip speed is unlocked. I also imagine any future upgrades from Pioneer won't take the 109 version but I'll have to use the A09 version. The A09 1.17 file went in without a hitch using the flash utility from Pioneer. This didn't work before now.
Anyway, these are only my results.  Prior to doing this it took over 30 minutes to rip DVD "X".  Now DVD "X" rips in just about 5 minutes.  Also noted is the fact that you can hear the drive spinning at maximum speed after the first few seconds of beginning to rip.  I monitored the rip with DVD Decrypter and was hitting 14X at the end of the disc.  DVD "X" was a single layer flipper disc with encrption....
Again, this is what worked for me.  Your results may vary.  Please don't blame me if you break your drive.  But again, it worked for me...
DVScuba
Bien entendu pour les plus téméraires d'entre-vous, qui tenteraient cet exploit, vous le faîtes à vos seuls risques et périls.
Tenez nous au courant de vos retours d'expèrience.
#2 Guest
Guest
  • Guests
  • 1 549 messages
Posté 12 avril 2005 - 19:30
Nos amis de "Blue-Hardware.com" viennent de mettre en ligne un article très complet expliquant comment transformer un DVR-109 en A09.
En utilsant le procèdé expliqué ci dessus.
C'est à lire ici : Débrider le PIONEER DVR-109D
#3 petitfuzzle
petitfuzzle
  • 16 messages
Posté 16 avril 2005 - 11:16
juste pour vous dire que je viens de faire la manipulation indiquée dans bluehardware, cela marche parfaitement, merci du tuyau saline. smile.gif
#4 Guest
Guest
  • Guests
  • 1 549 messages
Posté 16 avril 2005 - 11:27
QUOTE (petitfuzzle @ 16 04 2005, 12:16)
Oui, c'est plus facile à suivre, quand les explications données sont en Francais.
La transformation fonctionne parfaitement bien. La lecture est plus silencieuse, et surtout la vitesse d'extraction est libérée.
Merci de nous avoir informé de ton flashage réussi.
#5 Master's
Master's
  • 68 messages
  • Interests:La musique assistée par ordinateur (MAO), le piano, le triathlon et bien sûr le montage de mes vacances en DVD et SVCD... lol
Posté 05 mai 2005 - 15:14
Salut saline,
Quant tu dis "Il faut installer le graveur DANS un PC, pour faire cette manipulation" est-ce que tu entends que l'on peut aussi connecter simplement par firewire son graveur à son portable PC, ou faut-il impérativement l'installer dans une "tour PC"?
Car moi j'ai 2 Mac en fixe et un PC en portable (principalement pour travailler le son).
merci d'avance...
"C'est quand le jeu devient dur que les durs se mettent à jouer"
#6 Guest
Guest
  • Guests
  • 1 549 messages
Posté 05 mai 2005 - 15:35
QUOTE (Master's @ 5 05 2005, 16:14)
Il faut installer le graveur en interne dans une tour PC.
#7 filou131
filou131
  • 116 messages
Posté 15 mai 2005 - 17:32
QUOTE (saline @ 5 05 2005, 16:35)
Mais tu peux confirmer qu'une fois monter en firewire il aura la meme vitesse d'extraction que s'il était dans une UC ?
#8 Guest
Guest
  • Guests
  • 1 549 messages
Posté 15 mai 2005 - 18:02
QUOTE (filou131 @ 15 05 2005, 18:32)
Non !
Parceque je n'utilise pas de graveurs rapides installés en externe, tout simplement parceque le débit n'est pas suffisant pour exploiter toutes les possibilités de vitesse de gravure, pouvant être atteintes par ce type de graveurs.
Ainsi que je l'avais écrit et expliqué dans un sujet épinglé, que tu trouveras encore sur ce forum.
#9 filou131
filou131
  • 116 messages
Posté 15 mai 2005 - 20:32
oups, pardon, oui ça semble logique
#10 lesoufs
lesoufs
  • 16 messages
Posté 19 mai 2005 - 16:08
Question il semble dans le passé que des gens on flasher via Virtual PC en ayant leurs graveur en USB, Qu'en est-il si on branche le garveur en Firewire??
#11 Guest
Guest
  • Guests
  • 1 549 messages
Posté 19 mai 2005 - 16:26
QUOTE (lesoufs @ 19 05 2005, 17:08)
Nope, ça ne fonctionne pas !
Je l'ai d'ailleurs précisé en tête de ce topic ! ! ! ? ? ?
QUOTE (saline @ 8 03 2005, 14:45)
C'est toujours la même question portant sur la même "polémique" qui revient, sur les forums au sujet de virtual PC...
Virtual PC ne reconnait toujours pas, les graveurs externes connectés sur le port FW.
En USB, c'est un peu "Au petit bonheur la chance", en ce qui concerne les flashages de firmwares des graveurs, certains déclarent y être parvenus, d'autres pas, et certains d'entre eux ont même vu leur graveur rester bloqué, en "mode de protection du kernel", c'est à dire que le "kernel reste bloqué en "0000.
Et comme de toutes les façons après, le montage du graveur en interne dans un PC, est obligatoire pour essayer de le récupèrer...
Autant commencer tout de suite par cette manipulation !
Même si cette règle déplaît à certains "experts" de l'utilisation de Virtual PC sur Mac.
Aussi, tant qu'un flasheur n'existera pas sur nos Mac, l'installation du graveur dans un PC, pour le flasher restera la règle, que je conseille, et pas une autre !
Punto ! /
PS :
Maintenant, si tu veux procèder à tes propres tests, de flashage de ton DVR-109 en DVR-A09, en utilisant "DVRupdate", sous Virtual PC, avec ton graveur conneté au port USB, rien ni personne ne t'empêche de les faire à tes risques et périls.
#12 rico542
rico542
  • 11 messages
Posté 21 mai 2005 - 09:03
a lire il y a ici un bon recapitulatif :
forum hardware
#13 Guest
Guest
  • Guests
  • 1 549 messages
Posté 21 mai 2005 - 09:09
QUOTE (rico542 @ 21 05 2005, 10:03)
forum hardware
Ben oui, mais on y apprend rien de nouveau, par rapport à ce qui a été déjà écrit ici sur ce forum, et depuis fort longtemps, au sujet de la transformation du graveur Pioneer DVR-109, en graveur DVR-A09...
Merci tout de même, de ta participation dans ce topic.
#14 lesoufs
lesoufs
  • 16 messages
Posté 23 mai 2005 - 06:41
bon il semble y avoir du nouveau
Macbidouille
Je n'ai pas encore testé
#15 Guest
Guest
  • Guests
  • 1 549 messages
Posté 23 mai 2005 - 08:59
QUOTE (lesoufs @ 23 05 2005, 7:41)
Macbidouille
Nous si !
Et ça fonctionne.
Même que nous en avions parlé sur ce forum, dès le 14 Mai dernier... Et nous parlions d'un flasheur "Logitec", pour le modèle DVR-109 ! Non du flaheur pour le DVR-108 modifié, comme le fait l'utilisateur du site xlr8yourmac, auquel il est fait référence dans ton info...
voir :
I C I
Et les commentaires concernant cette "news" sont :
L A
#16 lesoufs
lesoufs
  • 16 messages
Posté 23 mai 2005 - 10:04
question j'ai un G5 avec un dvd-109 Apple dedans, est-il plus intéligent de le passer en A09, ou alors en 1.50 DVD-r 109 ??
#17 Guest
Guest
  • Guests
  • 1 549 messages
Posté 23 mai 2005 - 10:28
QUOTE (lesoufs @ 23 05 2005, 11:04)
Le firmware v.1.50, n'existe pour le moment qu'en version beta v.1.50b.
On en parle aussi, sur ce forum, et c'est ici :
http://forum.mac-vid...?showtopic=4043
PS :
Reprise de la "Campagne 1 clic par jour", oblige :
Sans passer, pour autant, du "côté obscur de la force", je vous rappelle de penser à cliquer sur le lien de pub Google, quand vous nous rendez visite, cela ne vous coûte rien, mais ça permet à "Jebe", de continuer à auto-financer son forum.
#18 Guest
Guest
  • Guests
  • 1 549 messages
Posté 24 mai 2005 - 10:57
QUOTE (saline @ 23 05 2005, 11:28)
Il n'aura pas fallu attendre trop longtemps.
Pioneer propose maintenant au téléchargement, la version définitive de ce firmware v.1.50, pour le DVR-109/A09.
On en parle ici sur ce forum :
http://forum.mac-vid...?showtopic=4253
#19 Guest
Guest
  • Guests
  • 1 549 messages
Posté 24 mai 2005 - 15:23
Récapitulatif :
1° - Pour ceux qui ont transformé leur DVR-109 en DVR-A09, en l'installant dans un PC et en utilisant "DVRUpdate".
La signature de leur graveurs est maintenant devenue "PIO-ADV" et il ne leur sera pas possible d'upgrader le firmware à l'aide du flasheur "Logitec" sur Mac.
Ce flasheur ne reconnait que les DVR-109 (OEM Pioneer) ayant pour signature "GENERAL" (Même en changeant le nom dans les fichier "kernel" et "firmware".
Donc upgrade du firmware dans un PC obligatoire.
2° - Pour ceux qui n'ont pas transformé leur DVR-109 en DVR-A09.
Il est possible d'upgrader leur firmware en v.1.50, en utilisant le flasheur logitec, en remplaçant le nouveau firmware et son fichier kernel dans le dossier contenant le flasheur "Logitec", par ceux d'origine après avoir renommés :
R9100009.150 -------> R9149009.140
R9100109.150 -------> R9149109.140
Le firmware du graveur sera bien upgradé en v.150, quelle que soit la version du firmware installé d'origine.
3° - Enfin, à l'attention de ceux qui n'ont pas transformé leur DVR-109 en DVR-A09, mais qui rèvent de le faire à l'occasion de l'ugrade du firmware.
Certains sont parvenus, à upgrader le firmware en v.1.50, en le flashant directement avec le firmware du DVR-A09 de la manière suivante :
1) - En prenant les 2 fichiers firmware et kernel du A09 :
R9143009.150
R9143109.150
2) - En les ouvrant au moyen de Textedit et en renommant les entêtes, PIO_ADV en ----> GENERAL
3) - En remplaçant le nouveau firmware et son fichier kernel dans le dossier contenant le flasheur "Logitec", par ceux d'origine après avoir renommés :
R9143009.150 -------> R9149009.140
R9143109.150 -------> R9149109.140
Mais ATTENTION :
En faisant cette "manipulation", leur graveur DVR-109, se trouvera équipé du firmware du DVR-A09, bien que la signature du graveur soit restée "GENERAL" et non pas "PIO-ADV" , comme elle devrait l'être.
Je ne conseille pas de le faire, car les futurs upgrades du firmware du graveur ainsi doté d'une "fausse signature", risquent de devenir très difficiles à réaliser en utilisant les moyens de flashage traditionnels.
Car ce type de graveur hybride (Un faux "PIO-ADV" renommé en "GENERAL"), mais tout de même équipé du firmware "PIO-ADV", risque de ne plus être reconnu pour un flashage ultérieur par aucun des logiciels de flashages qui seront mis à disposition sur le marché, y compris par un logiciel de flashage sur Mac, que nous finirons bien par avoir à notre disposition un jour ou l'autre... (On a le droit de rèver non ?)
Donc attention de ne pas avoir à regretter ce genre de manoeuvre, même si le prix de vente des graveurs à terriblement baissé...
En ce qui me concerne, j'ai effectué la mise à jour de mon graveur "transformé" en DVR-A09, en l'installant dans un PC et en utilisant le flasheur d'origine Pioneer.
#20 lesoufs
lesoufs
  • 16 messages
Posté 24 mai 2005 - 16:45
Et pour ceux qui ont un DVDR109 MAC ( celui des nouveaux G5 )
Il est impossible d'updater, à moins de fouiner dans le code du flasheur Logitec.
Modifié par lesoufs, 24 mai 2005 - 16:45.
