Ce qui n'est pas possible avec un firmware d'origine Pioneer.
L'explication complète pour le faire est fournie, par "William Donelson", sur le site "rpc1.org", c'est en Anglais (désolé j'ai la flemme de traduire, mais ce n'est pas très compliqué à comprendre) :
FINAL REPORT - DVR-109 for Mac OSX 10.3.8
I chose to use Buffalo v8.40 to get bitsetting so that I could play DVD+Rs that I make on my home DVD player. I will unlock fast ripping on my old DVR-106D if I can and use it to fast-read ("rip") the DVD videos etc.
Since there is not currently an app to do all of this on the Mac, I had to upadate the DVR-109 firmware on my PC first.
-- Here's what I had to do on the PC and the Mac --
PC First:
1) get the master file and extract the runtime .exe and data files:
. http://flashman.rpc1...falo109.840.zip
2) get the DVRupdate .exe application
. http://flashman.rpc1...update_v0.9.zip
3) Once you've extracted everything, put the "DVRupdate 0.9.exe" application into the "FW840" folder you got from step (1).
4) Run the "DVRupdate 0.9.exe" and Select the Small File "R9154009.840" as the Kernel, and the Large File "R9154109.840" as the Firmware.
5) The tray of the DVR-109 should open, and the DVRupdate should show some messages. Then you're done on the PC.
6) Remove the drive from the PC. Be sure to set up the PC again for the next guy...
Second, on the Mac:
7) Open your Mac and get ready. Set the MASTER (jumper pair 1) on the 109, and the SLAVE (Jumper pair 2) on any other CD/DVD drive on the chain. REMOVE the Fat Faceplate on the front of the drive drawer, if you have an MDD Mac or other tight-fit Mac bezel. Install it in the Mac and boot up.
8) Run PatchBurn to install the drivers for the Mac
. http://www.patchburn.de/
10) On your system profiler, ATA bus, your DVR-109 should now show "Vendor Supported" drivers.
Good luck !
If I made a mistake anywhere, PLEASE let me know.
William Donelson
N'ayant pas de graveur de DVd de salon, je n'ai pas essayé d'installer ce firmware d'origine "Buffalo".
Merci, à ceux qui tenteraient l'aventure, de nous faire part de leur retour d'expèrience, sur ce forum.
PS :
Et enfin pour ceux qui ne savent pas ce qu'est le "Bitsetting", ils peuvent aller lire un article publié sur ce sujet sur "cdfreak.com" (en anglais)
C'EST ICI
