Miglia propose une version beta du futur logiciel accompagnant le boîtier EvolutionTV.
Au menu : encodage direct au format iPod ou PSP et d'autres améliorations.
En détail et en anglais :
EvolutionTV 2.6 beta
, 12 janv. 06 22:43
Posté 12 janvier 2006 - 22:43
QUOTE |
Revision 2.6 Public Beta 1 - 11 January 2006 - Adds real-time compression for iPod Video. Video is encoded in MPEG-4 with two size options, the larger size is recommended if you watch videos stored on your iPod on your TV. - Adds real-time compression for Sony PSP - Includes iEPG plug-in that lets Japanese users access online TV Guides. - Includes Editing Plug-in for MPEG-2, MPEG-4 and DivX Movies. DivX movies are limited to 2 GB. - New overscan mode for the live TV window - Major changes to the video architecture. - Major changes to the audio architecture - Resolved bug that lead to picture corruption when the video window was resized and the picture optimisation turned off - Resolved bug that led to the initialisation of non-connected Bluetooth devices - Removed erroneous alert messages with the tvtv plug-in. - Update check no longer blocks the application on startup if the update check server is unreachable - Fixed setting for audio input in preferences - Removed double alert when quitting while a live recording is running - Fixed problem when the preferences dialog is opened while no device is connected |
C'est une version beta, donc c'est risqué. Pas de français non plus.
Lien direct de téléchargement (fichier .zip de 11 Mo) : http://www.miglia.co...nTV26PB.dmg.zip
Posté 18 janvier 2006 - 19:18
La 'Public Beta 1" est en fait la version 2.6 Beta 8, il ne devrait donc pas y avoir trop de danger
Il y a maintenant une beta 9 (non publique) qui ajoute l'integration iTunes pour les fichiers iPod.
http://beta.miglia.c...nTV_2.6.0b9.zip
